Renault COM diagnostics OBD2 palikka
joke66
Ihan hyvä palikkahan työ näyttäisi olevan.
Tällasia tietoja itse löysin näin äkkiä :
https://www.aliexpress.com/item/32793546313.html
Renault-COM Bluetooth is dealer level diagnostic and programming advanced device for Renault vehicles. It can access to various electronic control units (ECUs) such as Engine, Gearbox, ABS, Airbag/SRS. It can display identification, read and clear fault code memory, display and record measured values and perform actuator tests.
Renault-COM Hardware:
OBD2 to Renault-COM interface contains eight piceses of ISO9141 K-Line, one piece of ISO9141 L-Line, CAN-BUS and analog measurement circuits.
Operation System (OS): Renault-COM Bluetooth diagnostic interface is compatible with Windows 2000/XP/Vista/7/10
Renault-COM Features:
Fully multiplexed all-in-one Bluetooth interface
Automatic ECU recognition
Automatic vehicle scan
ECU Identification: – finds all the available ECUs in the car by pressing the single button
Bluetooth – wireless connectivity to your Windows laptop or tablet
Fault code (DTC) reading
Fault code clearing, with the ability to store DTC vehicle history forever
Freeze frame reading
Measured values / live data Live data recording, fully dynamic with graphing of up to 6 data streams at a time, recording and other manipulations
Diagnostic protocol printing
Actuator tests, test components via direct ECU access
Renault-COM Special Functions - perform dealer level high-end programming/coding such as:
Key programming
Service reset
DPF (Diesel Particulate Filter) regeneration
EGR (Exhaust Gas Recirculation) self-test
Airbag programming
Injector programming
Power Steering calibration
ECU replacement
Car configurations
Jos nuo kaikki toimii, niin hyvinhän tuolla pärjäilee.
coupe rellu
Itsellänikin on tällainen. Muistaakseni sain tällä vikakoodeja luettua, mutta se tärkein tehtävä ei onnistunut eli avaimen tekeminen. Jotenkin se juuttui siihen kirottuun auton valmistajan koodiin. Se sama joka estää myös toisen avaimentekolaitteeni käytön. Se on kyllä huutava vääryys, ettei auton omistaja saa auton mukana tätä koodia, vaan sitä varten pitää ostaa toinen ohjelma, jolla se koodi herutetaan auton järjestelmästä. Tässä vaiheessa antauduin ja jätin tilaamatta koodin luonti ohjelmatyökalun. Olin käyttänyt jo liikaa aikaa tämän kanssa, siksi kävin vain teettämässä uuden avaimen Tuurissa. Kätevää, kaupan valikoimia tutkiessani uusi avain synnytettiin, eikä tarvinnut rasittaa hermojani tietokoneohjelmilla. Pysyttelen mekaanisten vikojen parissa, tehköön ne tätä, jotka osaa paremmin.
meganekuski
Jonkin verran olen tutkaillut tuota Renault Com systeemiä mutta en oikein pääse perille että voiko tuolla ohittaa ajoneston?
meganekuski
No niin. Renault Com bluetooth laitetta olen silloin tällöin testaillut ja kokeillut eri käyttöjärjestelmissä.
Laite toimii hyvin:
-Windows 7
-Windows 8.1
Laitteen ohjelmisto ei toimi Windows 10:ssä.
meganekuski
Toimiiko tuo Renault scenicissä -99?
Ja torque softalla ios/androidissa?
Siis toi Renault com palikka.
Tuon laitteen kun tilaa niin siinä paketin mukana tulee tietokoneohjelmisto cd levyllä ja se asennetaan läppäriin. Ja nimenomaan Windows ympäristössä toimii.
Et tarvitse torque softaa.
Uskoisin että tuo laite toimii Scenic -99:ssä.
meganekuski
Toimiiko tämä -99 bensa rellujen kanssa? NexLink NL100?
Uskoisin että ei kovin hyvin toimi.
Edullisia Renaultille varta vasten tehtyjä olevia lukijoita ja ohjelmointilaitteita ovat:
-Renault Can Clip
-Renault Com Bluetooth
Noista tuo Renault Can Clip on kuulemma varsin perusteellinen työkalu.
Oma kokemus yleislukijoista Renaulteissa on sellainen että yleislukija lukee vain moottorinohjausboksin tietoja. Kaikki muut boksit kuten ABS, UHC ja Airbagboksit ovat pimennossa yleislukijalla.
Puuha-Pete
Ei valitettavasti toimi, kuten jo vastattiinkin. Jotain moottoriin liittyviä perusjuttuja saattaa saada näkyviin, mutta tuhon ei kannata kuitenkaan laittaa rahoja. Samasta kaupasta löytyy tällainen, jolla jo tekee renujen kanssa vaikka mitä:
Samoin moni Autel Maxidiag-sarjan laite on Renault-yhteensopiva. Vanhempia malleja, jotka kuitenkin pelittävät täysin tuon ikäisten autojen kanssa, löytyy välillä käytettynä sopuhinnalla.
Meganeee
Moro! Eilen saapui postissa tuo Renault Com palikka sekä Cd.llä ohjelmisto.. Ohjelman asennus Ja Bluetooth paritus onnistui, Mutta kun yrittää Ohjelmassa yhdistää ecu.un sanoo ohjelma suojausavain virheellinen.. Sama kaikissa muissakin toiminnoissa.. Kertokaapa joku fiksumpi Mitä pitäisi tehdä..?
meganekuski
En hirveästi osaa neuvoa tässä. Mutta löysitkö cd:ltä ne koodit jotka pitää syöttää ohjelmaan jotta se laite toimii?
maanma
Laitoithan varmasti avaimen Renault logon alle ja huolehdit, ettei koneella ole inet yhteyttä?
meganekuski
Erään tutun auto on Renault Kangoo 1,2 vm2004. Kokeilin tätä laitetta tuohon Kangoohon. Laite ei automaattisesti tunnistanut ecua ja siihen tuli valikko ecuista josta piti valita joku. En uskaltanut jatkaa pidemmälle. Niistä vaihtoehdoista ei mikään oikein tuntunut sopivalta kun vertasi ecun tietoihin mitä löysin moottoritilasta.
Ainakin oman autoni ecun tämä laite tunnistaa automaattisesti.
meganekuski
Tiedoksi tähän threadiin, että jos jollakulla on Renault Com ohjelmistocd hukassa, niin multa löytyy vielä tuo softa. Voin netin kautta lähettää sen.
Jukke
Voitko lähettää? Minulla on cd, mutta ei lähde toimimaan.
Tai voiko joku muu jolla löytyy cd laittaa vaikka linkkinä tiedoston
