Renault COM diagnostics OBD2 palikka
joke66
Laguna II Break 1.8
2
#21
Ihan hyvä palikkahan työ näyttäisi olevan.
Tällasia tietoja itse löysin näin äkkiä :
https://www.aliexpress.com/item/32793546313.html
Renault-COM Bluetooth is dealer level diagnostic and programming advanced device for Renault vehicles. It can access to various electronic control units (ECUs) such as Engine, Gearbox, ABS, Airbag/SRS. It can display identification, read and clear fault code memory, display and record measured values and perform actuator tests.
Renault-COM Hardware:
OBD2 to Renault-COM interface contains eight piceses of ISO9141 K-Line, one piece of ISO9141 L-Line, CAN-BUS and analog measurement circuits.
Operation System (OS): Renault-COM Bluetooth diagnostic interface is compatible with Windows 2000/XP/Vista/7/10
Renault-COM Features:
Fully multiplexed all-in-one Bluetooth interface
Automatic ECU recognition
Automatic vehicle scan
ECU Identification: – finds all the available ECUs in the car by pressing the single button
Bluetooth – wireless connectivity to your Windows laptop or tablet
Fault code (DTC) reading
Fault code clearing, with the ability to store DTC vehicle history forever
Freeze frame reading
Measured values / live data Live data recording, fully dynamic with graphing of up to 6 data streams at a time, recording and other manipulations
Diagnostic protocol printing
Actuator tests, test components via direct ECU access
Renault-COM Special Functions - perform dealer level high-end programming/coding such as:
Key programming
Service reset
DPF (Diesel Particulate Filter) regeneration
EGR (Exhaust Gas Recirculation) self-test
Airbag programming
Injector programming
Power Steering calibration
ECU replacement
Car configurations
Jos nuo kaikki toimii, niin hyvinhän tuolla pärjäilee.
1
#23
Itsellänikin on tällainen. Muistaakseni sain tällä vikakoodeja luettua, mutta se tärkein tehtävä ei onnistunut eli avaimen tekeminen. Jotenkin se juuttui siihen kirottuun auton valmistajan koodiin. Se sama joka estää myös toisen avaimentekolaitteeni käytön. Se on kyllä huutava vääryys, ettei auton omistaja saa auton mukana tätä koodia, vaan sitä varten pitää ostaa toinen ohjelma, jolla se koodi herutetaan auton järjestelmästä. Tässä vaiheessa antauduin ja jätin tilaamatta koodin luonti ohjelmatyökalun. Olin käyttänyt jo liikaa aikaa tämän kanssa, siksi kävin vain teettämässä uuden avaimen Tuurissa. Kätevää, kaupan valikoimia tutkiessani uusi avain synnytettiin, eikä tarvinnut rasittaa hermojani tietokoneohjelmilla. Pysyttelen mekaanisten vikojen parissa, tehköön ne tätä, jotka osaa paremmin.
