Renault Clio II ajovalot lakkasi toimimasta... Rele/sulake kunnossa, samoin valo viiksi, mitattu on!
Mikä laite ohjaa valoja onko UCH boksi?
Olis kos jollain sähkökaaviota olemassa?
ELECTRICAL ASSISTANCE EQUIPMENT
UCH 87
87-7
CONFIGURATION OF THE UCH
The configuration options for the UCH are:
Title and position on the diagnostic tool Configuration Type of UCH
Timed courtesy light (LC 021) automatic all types
Arabia overspeed (LC 068) manual all types
Daytime running lights (LC 049) manual N3 only
Rain sensor (LC 051) manual N3 only
Light sensor (LC 055) manual N3 only
Second fitting alarm (LC 066) automatic N3 only
Automatic relocking (LC 069) automatic all types
Windscreen wiper timing (LC 070) manual (incompatible with
the rain sensor)
all types
Headlight washers (LC 073) manual N3 only
Passenger's one-touch window (LC 074) manual N3 only
Additional wiping after windscreen washer
(LC 071)
CONFIGURATION OF THE PASSENGER COMPARTMENT CONNECTION UNIT
Using a diagnostic tool:
– With the ignition on, enter dialogue with the vehicle and perform the multiplexed network test,
– Select and confirm the Passenger compartment connection unit menu,
– In the Command mode menu, select and confirm the Configuration line,
– Select the command CF 718: UCH type,
– Message: Warning! the first stage of the procedure involves erasing the UCH configurations. If the
procedure is interrupted after this stage, the computer will be completely deconfigured. Do you wish to
proceed? appears,
– Select yes,
– Message: Erasing the computer memory appears,
– Select the type of UCH that corresponds to the vehicle N2 or N3. Refer to the operations table,
– Message: Do you wish to proceed? appears.
– Select yes then perform the manual configurations,
For the bottom of the range UCH or N2
1 Configuring the Arabia overspeed,
2 Configuring the variable timing of the windscreen wiper (only if the vehicle is not fitted with a rain sensor),
For the top of the range UCH or N3
2 Configuring the windscreen wiper variable timing (only if the vehicle is not fitted with a rain sensor),
3 Configuring the light sensor (incorporated into the rain sensor depending on the version),
4 Configuring the rain sensor
5 Configuring the headlight washers (specific to headlights with xenon bulbs),
6 Configuring the daytime running lights for vehicles fitted with top of the range wiring (discharge bulb),
7 Configuring the passenger's one-touch window.
– When changing option, select the line to be changed then confirm reverse,
– The desired configuration changes,
– Select Configuration then confirm,
– The message: Are the configurations correct? appears,
– Select yes,
– Check that the configurations have been carried out correctly using the configuration reader screens.
